Davepp
Hi There,
I’m working on a site and have added a custom header element with two buttons that should sit on the right on ipad & in the centre for mobile (site details in private info) the current styling works fine across all screen sizes & devices apart from anything safari ios. Help would be fantatstic!
1. On mobile, select the parent container with class
gb-element-9dd3b403
, and setflex-wrap
towrap
.2. On mobile, select the button container with class
gb-element-244000a2
, setposition
torelative
,float
tonone
,left
,right
,top
to0
,min-width
to100%
.Let me know if this helps!
Davepp
Thanks,
Well, things are looking better on ipad, but on firefox etc everything is out of alignment in the header & the first content section seems to be being pushed to full width. Any suggestions?
Are you referring to the Firefox browser layout at the iPad breakpoint? I don’t have an actual iPad to test with, but using a simulator, I wasn’t able to replicate the issue you mentioned. If possible, could you share a screenshot? That would help a lot!
Davepp
Thanks,
Was a strange one, but ultimately it was the flex wrap to wrap that sorted it. I’d hacked my way through the alignment using a variety of margins and floats, but rebuilt that entirely to use the flex properly.
Glad to know that!
