Avadhut
Is this font available in GP theme?
Font: Be Vietnam Pro.
Thanks.
That is a Google Font, but you can add it through Customize > Typography > Add Font. Simply search for the font name in the select font field, and it should be available.
Avadhut
I have already added it here: https://ibb.co/x2LTKzk
But, during page designing, in Block setting’s Typography, this is not coming. Only “Be Vietnam” is coming, and not “Be Vietnam Pro”. https://ibb.co/D1NRPrK
What’s the issue?
If you want to use the font that is already set in the customizer, you should not set the font at the block level. It should automatically inherit the font that you configured in the customizer.
