Is this possible? Allow creating elements when NOT using GP theme
  • Hiya
    Sorry if this is a feature request more than an issue
    I would like to ask if its possible to have the elements section available even when the active theme is not GP
    The reasoning is – when I upgrade sites to GP – often I create on a demo site and than transfer across – I can export JSON files for most of GP but not elements – and so I need to create those from scratch
    I have to take the site offline to create those elements – which takes time – not much, but time
    If I could pre-create them – even if there is a notice saying these cannot work until GP is selected theme – that would vastly improve the speed I can updates site. Exporting and importing elements would also be fab! But just having access to elements early woudl make a huge difference
    Will it ever be possible?
    Thank you
    Sarah
    It’s not possible, unfortunately!
    GP Premium plugin only works with GP theme.
  • Thanks Ying – as I expected – is there anyway that elements can be imported/exported at all ? In case I am missing something?
    At the moment, Elements can’t be imported or exported separately. They’re stored in the database and tied to the GP theme, so there isn’t a built-in import/export option.
    The only way right now is to use a full site migration or a database export/import if you want to move them between sites.
    I’ll also make a feature request so the team can consider adding import/export support for Elements in future updates.
  • Thank you Chaz – a feature request would be perfect – thank you – as that would certainly save a heap of time!
    And yes whilst if its a site from scratch a full migration works – when you are doing a face lift shall we say its not quite as straight forward
    Thank you – always worth asking the questions!
    You’re very welcome. I can see how a facelift project makes it trickier compared to a full migration. Your feedback is really helpful, and I’ve noted it along with the feature request.
  • if its aface lift for my clients that is simpler as GP already in use and I can pre-create the elements – but when taking over a new client or face lift a really old website (my pre GP era!!!) then that is when its needed
    That makes perfect sense , thanks for clarifying. I’ve added that context to the feature request, so the team understands how it helps most when working on older, non-GP sites.
