Issue on Buttons / gb-button class
    I’m using the newly updated generate blocks pro, but am getting a weird issue on button styling.
    When I insert a button, the generate blocks styling panel is not apply a text colour, even when I told it to be white.
    Looking at the code, I can see that the class gb-button isn’t being applied to the buttons, so would struggle to fix this font colour in css code (in one line for all instances of buttons).
    I have everything up to date and the premium theme installed too. I’ve also checked that I’m inserting GB buttons, rather than wordpress standard ones.
    Could you have a look please?
    Luke
  • Hi luke,
    The buttons on your homepage have white text.
    However, the white text is from the content link color you set at customizer > colors > content.
    If you remove the link color from customizer, the button’s block-level style should kick in.
    Let me know if this helps!
