fortyfivecreative
Hi, as per the screen grab on the link below, I’m using a query loop which includes ‘list terms’ for a ‘Destination’ taxonomy. Each post has a parent and child taxonomy term, and I’d like to always display the child THEN the parent. At the moment, it’s just outputting in alphabetical order, regardless of whether each term is a parent or child. Can you please help? Thanks! David
You’ll need a custom solution for this.
Here are a few steps:
1. Under your Headline Block for the Destinations taxonomy, add another Headline Block.
2. Add this class:
cu-destinationsAdding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/3. Add this snippet:
// Create a custom sorting function to order terms by parent-child relationship function custom_term_sort($a, $b) { // Get term hierarchy level $level_a = count(get_ancestors($a->term_id, 'destinations')); $level_b = count(get_ancestors($b->term_id, 'destinations')); if ($level_a === $level_b) { return strcasecmp($a->name, $b->name); // Sort alphabetically when at the same level } return ($level_a > $level_b) ? -1 : 1; // Sort by hierarchy level } add_filter( 'render_block', function( $block_content, $block ) { if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'cu-destinations' ) !== false ) { $current_post_id = get_the_ID(); // Get all "destinations" terms for the current post $destinations = wp_get_post_terms($current_post_id, 'destinations'); // Sort the terms using the custom sorting function usort($destinations, 'custom_term_sort'); // Loop through the sorted terms and display their names with links to term archive pages if (!empty($destinations)) { $block_content = '<div class="destionation-container">'; foreach ($destinations as $destination) { $term_link = get_term_link($destination); // Get the link to the term archive if (!is_wp_error($term_link)) { $block_content .= '<a href="' . esc_url($term_link) . '">' . esc_html($destination->name) . '</a><br>'; // Display the term name with link } } $block_content .= "</div>"; } } return $block_content; }, 10, 2 );Adding PHP: https://docs.generatepress.com/article/adding-php/#code-snippets
Make sure to replace
destinationsin the code with your taxonomy slug.4. Delete the other Headline Block.
Let us know how it goes.
fortyfivecreative
Hi Fernando, Unfortunately this is still outputting in the same alphabetical order as before, rather than child then parent. The results mirror exactly the original headline blovk before this custom sort block. Thanks
fortyfivecreative
Sorry! My fault, all working, thanks. I now just need to output the block as per the original block i.e. comma separated list with an icon to the left (as per the sccreenshot on the ticket). Are you able to help me adjust your custom function to achieve this? Thanks again!
remove the code Fernando provided, and instead try this:
function custom_get_the_terms_order($terms, $post_id, $taxonomy) { // check the taxonomy you want to apply it to if ($taxonomy === 'your_taxonomy') { $ordered_terms = array(); $child_terms = array(); $parent_terms = array(); foreach ($terms as $term) { if ($term->parent === 0) { $parent_terms[] = $term; } else { $child_terms[] = $term; } } // Sort child terms alphabetically usort($child_terms, function ($a, $b) { return strcmp($a->name, $b->name); }); $ordered_terms = array_merge($child_terms, $parent_terms); return $ordered_terms; } return $terms; } add_filter('get_the_terms', 'custom_get_the_terms_order', 10, 3);Note this line:
if ($taxonomy === 'your_taxonomy') {change theyour_taxonomyto what tax you want to apply it to. -
fortyfivecreative
Works perfectly, thank you!
Glad to hear that
