Issue with GenerateBlocks patterns
  • Hey,
    I’m trying to add a pattern to the GenerateBlocks library, but for some reason, even though it saves, I can’t use it anywhere on the site.
    Here’s a quick video that shows what’s happening: https://take.ms/DfApI
    That container includes a few GreenShift blocks.
    Any idea how to fix this?
    I’ve also set up a temporary access URL to the site.
    I can not replicate the issue on my site, so it’s something specific on your site that causes the issue.
    Try creating a staging site, disabling all your plugins except GB, GB Pro and GP Premium and switching to the parent theme to test.
    Let me know how it goes 🙂
  • Is there any other way to troubleshoot it?
    It’s a pretty large site, and creating a staging environment could take a day or more because of the size of the database.
  • All plugins need to be deactivated and the parent theme needs to be activated to do proper debugging, unfortunately!
    By the way, the pattern feature is from WordPress, you can also try creating a pattern with another block plugin instead of GB, does that work?
    If not, then you have something that is conflicting with the core WP feature.
