Hi George & team,
The top menu is not working on mobile devices. I haven’t made any design modifications to this component yet.
I’ve attached two screenshots for reference: https://postimg.cc/gallery/kS4xyz4
The issue on my current build.
The original template working correctly. Link to the original template to see the menu in mobile: https://sites.generatepress.com/headline/
Could you please advise on how to resolve this?
Thank you,
Eric
George
Hi Eric,
Do you have a URL we could see?
Yes, here you have: https://serra.immo/blog/
Thank you!
George
Can you please deactivate W3 Total Cache and try again?
I have deactivated W3 Total Cache and tried again in incognito, but no luck 🙁
What else could it be?
Thank you
George
The off canvas (slideout) panel is enabled for mobile on your site, but no menu is assigned to it, so the panel opens empty. In the page source the slideout navigation contains only the close button and no menu items.
To fix it, go to Appearance > Menus, select the menu you want to use, and under Menu Settings / Display location tick Off Canvas Menu (you can assign the same menu that’s already on Primary Menu — a menu can have more than one location). Save, then reload on mobile.
More details here: https://learn.generatepress.com/classic-theme/off-canvas-panel/#off-canvas-panel-overview–empty-off-canvas-navigation
It works George, many thanks! Is there a way to change the background color? Screenshot here: https://postimg.cc/sGQhVfx5
Many thanks again,
Eric -
George
Yes, Customize -> Colors -> Off Canvas Panel, change Navigation Background colors.
You’re the best, thank you George!
George
Glad I could help, you are welcome!
