gedosan
There appears to be an issue with mobile that has persisted for a while. Still getting the issue, even in incognito.
G -
The parent container of the list in the page hero section has a static
widthset to 600px, so it overflows when the mobile screens:
https://app.screencast.com/bBTHVzCuKBiQ4Remove the 600px from the
widthfield, add it tomax-widthfield instead. -
gedosan
Great thanks
No Problem 🙂
gedosan
Hi Ying
Appears to be doing it again?
Ged -
I do not see the issue.
gedosan
Sorry was cached I think…if you scroll down the page on mobile there’s no padding, is there an obvious fix for that?
You’ve set the sections’ padding-left and padding-right to 0rem, so it’s expected there’s no padding.
For example .gb-element-b1cb26da (CUSTOMER TESTIMONIALS).
Simply remove the 0 from the paddings field should fix the problem.
gedosan
I’ve managed to get one section to behave, but not the rest. If I share the log in details is there any chance you could do it for me? I fear I may be here another couple of hours trying to figure this out!
Ged
Our job is to guide you to achieve what you want, we can not do it for you, unfortunately!
You are using
gbp-section-innerfor some root containers, that global style is meant for inner containers not root containers, so remove this global style, and usegbp-sectionglobal style instead.For example: gb-element-6fcbb93a (SIZES & Pricing), gb-element-c66b8b0a(Location)
gedosan
sorted it
Nice 🙂
