sarveshmathi
Hi, I have a few issues with setting a background video on my home page hero section even after following the instructions outlined here: https://docs.generatepress.com/article/adding-a-background-video/
1. The text is not overlaying on the video. Instead, it goes below, despite setting the z-index values according to instructions.
2. The video auto-plays on Chrome but not on Safari desktop. It instead shows a play button. Also, the poster image does not occupy full width and height.
3. The opacity of the video is not changing despite setting it in CSS.I have shared the website details and access privately in case you want to take a look.
Try adding the CSS to the top of your CSS field to eliminate syntax errors from previous CSS.
And I tested on Safari, it auto-plays with no issue, I don’t see a play button.
Let me know if this helps!
sarveshmathi
Yes, that helped in fixing the text overlay issue. However, I’m still unable to change the opacity of the video.
The opacity looks correct to me:
https://app.screencast.com/lUw4k69IxSS0y -
sarveshmathi
I think you shared the wrong screenshot.
The opacity seems to be hit or miss. Currently, it isn’t working for me. I’m also getting a play button on Safari instead of the video auto-playing: https://ibb.co/SBcnd2p
I viewed the site in Safari, and the video is auto-playing.
Also, the opacity works when I adjust the opacity value in the Customizer’s CSS.
sarveshmathi
Okay, it’s working on and off. Maybe some issues with my browser. Thanks a lot!
No problem!
