Journal Theme Issues
    I can’t seem to be able to align sidebars, content shows duplicates on the same page such as 2 lists of the same posts, etc.
    Is there any documentation on how to set it up?
    Thanks.
    R
    The Journal homepage is a static page, it does NOT have the default sidebars, however, you’ve enabled the sidebars which breaks its original layout.
    To edit the “right sidebar” on the homepage, you can edit the page directly.
    For the single post, the sidebar is built with a block element – sidebar, which can be accessed from Appearance > elements > Right sidebar single post.
    For the archives (category/tag archive), the sidebar is also built with a block element – sidebar, which can be accessed from Appearance > elements > Right sidebar archive/blog.
