Keeping containers the same size
  • Hello. How do I create two block grid where the two blocks have the same equall size as the screen size is reduced until it flips to tablet/mobile view?
    Select the Image block on the left side of the grid hero section, then set both its width and height to 100%.
  • Unfortunately that didn’t work. On my laptop, I set my browser to the size just before the example switches to a tablet view and the image is stil higher than. Also, I prefer the size of the image at the 80%.
    I’m guessing the issue is then I have too much text?
  • You can keep the image Max Width set to 80%. What I’m referring to are the Width and Height fields under the Sizing block settings of the Image block—set both of those to 100%.
  • My bad, that worked….thanks!
  • No problem! 🙂
