PaddyD
https://crystalyaki.ca/test/looking-to-build
The desktop and tablet layout are fine as is, but on mobile phone the button sits on Mike’s head – we’d like to fix that. 😉
I’ve tried all the normal settings for moving a button to the bottom of a container but it won’t budge. I probably have another setting in there that’s preventing it, but can’t figure out what.
I’d like the button centred at the bottom with 20-40px margin on the bottom.
1. Reduce the
padding-bottomfor.gb-element-0108f88fon mobile.2. Set
flex-growto1for.gb-element-7510d1b9.3. Set
margin-toptoautofor the button. -
PaddyD
Did all that (#3 was already done) and it moved down a bit, but still not at the bottom of the image section.
Try setting the
.gb-element-7510d1b9padding-bottom and margin-bottom to 0. Then, select the Button block and set its margin-bottom to 0 as well. -
PaddyD
Thank you – that worked! Finally…
You’re welcome, glad to hear that!
