Anonymous
Hi team,
I am having trouble with the layout setting and having tried lots of various Display & Alignments without success, ask your help.
As you will see, I have created Headlines that are made up of 2 types of font. Looking at these on a desktop, the flex setting work nicely and show the headlines in a neat row. But when I shrink the screen, both headlines go to double rows. I would prefer that when shrunk the second headline font type, is placed below the first. How do I set up the Layout to accomplish this?
Try setting the Flex Wrap option for
.gb-element-c4a1cfe2to Wrap. -
Anonymous
Tahnks Alvind,
That kind of worked, but still something odd happening as I reduce the width of the screen?
The only issue I can see is that the Leave The Planning text is aligned to the right when reducing the screen width. I’m not sure if you’re referring to something else.
To fix that, simply select the Text block and set its Text Alignment to Left.
Anonymous
Yes, I think perhaps I was confusing it with different left / right settings for each part. All fixed now, thanks Alvind.
No problem, glad to hear that 🙂
