Layout Woocommerce is damaged
    We experience a weird layout behavior on pages 2 and 3, where the layout overlaps the menu and navbar. Please see a screenshot here https://imgur.com/x4xRosH Could you please check?
    Thank you!
    It’s expected behaviour as you hide the page hero on page 2,3, but the merged header is still working.
    Try this CSS to stop the merged header:
    body.archive.paged .header-wrap {
        position: relative;
    And try this CSS for the navigation/logo color.
    @media(min-width: 769px) {
    body.home.paged .header-wrap {
        position: relative;
    body.home.paged .site-logo.page-hero-logo img {
        filter: invert(1);
    body.home.paged .header-wrap #site-navigation:not(.toggled) .main-nav > ul > li > a, .header-wrap #mobile-header:not(.toggled):not(.navigation-stick) .main-nav > ul > li > a, .header-wrap .main-navigation:not(.toggled):not(.navigation-stick) .menu-toggle, .header-wrap .main-navigation:not(.toggled):not(.navigation-stick) .menu-toggle:hover, .main-navigation:not(.toggled):not(.navigation-stick) .menu-bar-item:not(.close-search) > a {
        color: #000;
    body.home.paged  .header-wrap #site-navigation:not(.toggled) .main-nav > ul > li[class*="current-menu-"] > a {
        color:#00aa95;
  • Hi Ying,
    Thanks, that’s perfect. When I want to show the site logo instead of inverting it, how could I do that? The reason is that the logo is not only black but also has some green in it. On the background image, that’s okay with just being white, but on the white background, it has to be the site logo.
  • When I want to show the site logo instead of inverting it, how could I do that?
    I think a better approach is to disable the header element on paged pages.
    Remove the 2nd CSS in my previous answer, and add this PHP code instead, replacing 100 with the actual header element ID which you can find in the URL when you edit the element.
    add_filter( 'generate_element_display', function( $display, $element_id ) {
        if (
            100 === $element_id &&
            is_front_page() &&
            get_query_var( 'paged' ) >= 2
            return false;
        return $display;
    }, 10, 2 );
