Stefanski
I’m using Elements -> Block/Loop for some archive pages and the native GP-archives (Customiser->Layout->Blog->Archive) for others.
– Native GP-archives are assinging loading=”lazy” for images below the fold as expected in WP.
– Images in the Block/Loop don’t – neither with “GP Dynamic Images” nor with “GB-Image” & Dynamic Tags in the loop.fyi: I don’t use wp_omit_loading_attr_threshold in my functions.php
Any ideas on how to get back lazy loading for my images?
Thanks in advance
Stefanski -
I can not replicate the issue.
Can you link me to the page in question?
Stefanski
Link in private Infobox
You are using the v1 query loop block. Is there any chance you can use the v2 query block instead?
Stefanski
Yes, see PM, please.
Hi Stefanski,
In your V2 Query block, the
loading="lazy"attribute is present on the images. You can see it here:
https://cln.sh/jG7L8nvFRTz7yZPS1Sj0 -
Stefanski
Hi Alvind,
great, thank you – I missed it, because the page was still cached.
Stefan
Glad to hear that 🙂
Stefanski
Hi Alvin,
one more thing: Now every image inside the loop has loading=”lazy”.
How can I remove lazy for the first x images in this loop-setup?None of the usually suggested methods (omit threshhold etc) seems to work for the Loop-Block.
Tanks
Stefan -
Hi Stefan,
By default, the first image in the loop won’t have the lazy-loading attribute. Are you looking to remove that attribute from additional images as well, for example the first three images? Is that the scenario you’re trying to achieve?
Stefanski
Yes, exactly. I need the option to unset “lazy” for the first x images and ideally add “eager” to them.
btw: my first image in the loop has the lazy-attribute, too.
Stefanski
additional info in PM
George
Hi Stefan,
Try this method:
add_action('template_redirect', function() { if (!is_archive() && !is_home()) { return; } ob_start(function($html) { $eager_count = 3; // Number of images to set as eager $counter = 0; $html = preg_replace_callback( '/<img\b([^>]*)\bloading=["\']lazy["\']([^>]*)>/i', function($matches) use (&$counter, $eager_count) { $counter++; if ($counter <= $eager_count) { $tag = '<img' . $matches[1] . $matches[2] . '>'; $tag = str_replace('<img', '<img loading="eager"', $tag); if ($counter === 1) { $tag = str_replace('<img', '<img fetchpriority="high"', $tag); } return $tag; } return $matches[0]; }, $html ); return $html; }); });Adjust
$eager_countto control how many images getloading="eager". The first image also getsfetchpriority="high"which helps with LCP. Adjust theis_archive()/is_home()condition to match whichever pages your loop template displays on. -
Stefanski
Hi George,
thanks for the code – this works although the method is somewhat “brutal”…
Is there no more elegant method than manipulating the HTML output using regex?
Stefan -
George
I found a more targeted solution using a GenerateBlocks internal filter. This hooks directly into GB’s rendering pipeline, so it only affects media blocks inside query loops — no output buffer or page type conditions needed:
add_filter('generateblocks_before_dynamic_tag_replace', function($content, $args) { $block_name = $args['block']['blockName'] ?? ''; if ('generateblocks/media' !== $block_name) { return $content; } if (!class_exists('WP_HTML_Tag_Processor')) { return $content; } $in_query = isset($args['instance']->context['generateblocks/loopItem']); if (!$in_query) { return $content; } $loop_index = $args['instance']->context['generateblocks/loopIndex'] ?? 0; $eager_count = 3; $processor = new WP_HTML_Tag_Processor($content); if ($processor->next_tag('img')) { if ($loop_index <= $eager_count) { $processor->set_attribute('loading', 'eager'); if (1 === $loop_index) { $processor->set_attribute('fetchpriority', 'high'); } } else { $processor->set_attribute('loading', 'lazy'); } $content = $processor->get_updated_html(); } return $content; }, 10, 2);It uses GB’s loop context to identify the position of each image in the loop, then sets
loading="eager"andfetchpriority="high"on the first image for LCP,loading="eager"on images 2-3, and explicitloading="lazy"on the rest. You can adjust the$eager_countvalue if needed. -
Stefanski
Hi George,
the new code works like a charm.
Thank you for your support
Stefan
