Greetings.
The following websites use GP Premium theme and GB plugin.
Can we use an lead generation plugin (such as Brave Builder https://getbrave.io/) to create layouts? I hope the Brave builder will not clash with GB plugin because both are in a way page builders?
Please help understand how this will work and if we must keep anything in mind before using Brave plugin.
Thank you.
Unfortunately I’m not familiar with the Brave Builder plugin.
Does it use the block editor? If so then you should be able to use it along with GB.
If it uses its page builder UI like Elementor or BB then that wouldn’t work.
The best way to determine this is to start a staging site and test it there.
I hope this helps.
Thank you for your response.
Please review the response from Brave plugin in WP forum and, once again, let me know your thoughts.
So they do not use block editor, then you will not be able to use GB along with Brave.
But you should be able to use it with GP.
Ying,
Thank you for you response.
Do you know of any lead generation plugin whose editor will not clash with GB?
I just did a quick search on Brave documentation, and it seems like they provide a shortcode that you can use to embed their form:
https://getbrave.io/documentation/how-to-embed-in-posts-pages/ -
Alvind,
Many thanks for the link and clarification.
You’re welcome!
