Maznet
Hi, I’m rebuilding a site using the Agency template and wondered how to set the logo to appear in the top left-hand corner and the navigation in the top right.
Can you try disabling all CSS before
/* GeneratePress Site CSS */
in the customzier > additional CSS? -
Maznet
Thanks Ying, that did the trick.
Maznet
Do you know how I increase the height of this primary navigation header section?
Can you link me to the site again?
The info has been removed when it’s marked as resolved.
Maznet
See below.
It’s using navigation as header option, so the height is controlled by the menu item height.
Go to customizer > layout > primary navigation, and increase the menu item height.
Maznet
Thanks again Ying.
No Problem 🙂
