anwegner
I’m working on a subdomain for this website (https://dairylandsports.org/), but using a different theme and builder for various reasons.
I found other help articles about how to code a hover underline in the primary nav, but I can’t quite get them to work and be similar (identical) to the main site above. Specifically, how do I make the hover underline tighter to the bottom of the nav text and the width aligned to the width of the nav text?
The test subdomain: https://ds2.anwegner-testing.com/
Thanks,
Amanda -
Hi Amanda,
Under your Customize > Additional CSS, replace this CSS block:
/*Menu Styling*/ .main-navigation .menu>.menu-item>a::after { content: ""; position: absolute; left: 0; /* Starts the underline from the left */ bottom: 15px; -webkit-transform: translate3d(-40%, 0, 0); transform: translate3d(-50%, 0, 0); display: block; width: 0; height: 2px; background-color: red; transition: 0.3s width ease; } .main-navigation .menu>.menu-item.current-menu-item>a::after, .main-navigation .menu>.menu-item.current-menu-ancestor>a::after, .main-navigation .menu>.menu-item>a:hover::after { width: 100%; }with this:
.main-navigation .menu > .menu-item > a::after { content: ""; position: absolute; left: 50%; bottom: 15px; transform: translate3d(-50%, 0, 0); display: block; width: 0; height: 2px; background-color: red; transition: 0.3s width ease; } .main-navigation .menu > .menu-item.current-menu-item > a::after, .main-navigation .menu > .menu-item.current-menu-ancestor > a::after, .main-navigation .menu > .menu-item > a:hover::after { width: 80% } -
anwegner
Thank you, Alvind! Perfect!
You’re welcome!
