I have a number of strange issues with this site:
https://energyhealinginstitute.org/In the last few days, I made a number of changes in the customizer:
Changed main navigation from all caps to normal
Changed to SVG Icons
changed from legacy to new typography systemI’ve cleared every cache in the universe but here’s what happening:
The site first loads the previous all caps lighter colored menu items, then after a few seconds it loads the new one
The site also loads two icons – whether that’s the drop down arrow in the main navigation or the menu icon on mobile — you see two of them.
the second problem I have is the purple CTA in the hero section; it is set to white font and shows correctly when logged in but it pulling the font color set in Body for links.
George
Issue 1: Flash of old menu styles (FOUC)
This is a Perfmatters delayed styles problem. Look at the bottom of the page source:
!function(){const e=["keydown","mousemove","wheel","touchmove","touchstart","touchend"]; function t(){document.querySelectorAll("link[data-pmdelayedstyle]").forEach(...Perfmatters is deferring most stylesheets — including
generatepress-dynamic-css(which contains your Customizer changes) — until user interaction. On first paint, the browser renders with whatever is in the critical/used CSS cache (front.used.css), which still contains the old all-caps, lighter-colored nav styles. A few seconds later the deferred styles load and the new styles kick in.The fix is to regenerate Perfmatters’ critical CSS so it picks up your Customizer changes:
- In WP Admin → Perfmatters → Extras → Critical CSS — delete/regenerate the critical CSS for the front page
- Also clear the Used CSS cache specifically: Perfmatters → Tools → Clear Used CSS
- If you’re using the “Delay JavaScript” feature, make sure
generatepressscripts aren’t being delayed in a way that compounds this
If Perfmatters has a “Remove Unused CSS” or “Used CSS” feature enabled, that
front.used.cssfile needs rebuilding after every significant Customizer change. That’s your culprit.As a quick test to confirm: disable Perfmatters temporarily — if the flash disappears, that’s your answer.
As far as the button is concerned: Regenerating the Used CSS should fix it cleanly without needing any additional overrides. Once you’ve done that, test logged-out in a fresh private/incognito window to confirm.
Oh, man this is the second time I’ve spent hours trying to figure something, then reached out here, only for GP support to let me know it’s Performatters — think I’m’ gonna ditch that plugin!
I disabled and everything is fine now!
Thank you!
George
Ok, no problem!
