license activation issue
  • Hello – I appear to be having the same issue as the user in this discussion – https://generate.support/topic/generateblocks-license-key-problems/
    I have just created a fresh WordPress install, and by using my GeneratePress One license key I am able to successfully activate GP pro and GP cloud, but I am receiving a non-specific error when the same license key is entered for GenerateBlocks – “An error occurred, please try again.”
    I contacted my web host (DreamHost), and they said that cURL is enabled, and that “there is nothing in the server that would cause this issue.”
    Suggestions?
    Thank you!
    Meg
    Can you provide an admin login with your GP ONE license so we can have a try at the backend?
  • Hi Ying… requested info provided in private info box – thank you!
  • It says “The username tempadmin is not registered on this site.” can you check?
  • I just double checked and the login is correct… please try again?
  • I logged in this time 🙂
    Have you seen this article?
    https://docs.generateblocks.com/article/license-key-activation-issues/
    To fix this issue, please contact your host and ask them to allow your WordPress installation to communicate with https://generateblocks.com using the wp_remote_post function.
    I assume you’ve asked your host to do this? And they already did?
  • Hi Ying – yes, I mentioned that in my initial post. I specifically asked them to do that, and they said that they did, and that they do not see any reason from their end that it should not be working.
  • I shared this link with the support chat person from Dreamhost – https://docs.generateblocks.com/article/license-key-activation-issues/
  • OK, in this case, can you provide your site’s IP address so we can check if it’s blocked on our end?
  • 173.236.246.42
  • Thanks! We’re investigating the issue. It looks like our host has your server IP blocked, and we’ve escalated a ticket to have it unblocked. I’ll update you once that’s done.
    Thanks for your patience!
  • Hi Tom – thank you! This website having the problem is a new WP installation in a subfolder. GP-Premium and GB-Pro are both active and licensed successfully on the root folder WP installation (same IP address), but I have not yet upgraded those to the GP-One license. Could that possibly be a reason that a block was triggered?? Funny, though, that the block is only happening for GB-Pro, because GP-Premium and GP-One accepted the license keys successfully.
  • I believe it’s because the GB license field goes through our GB website, and that’s where the block was happening.
    Can you try now?
  • Hi Tom – sorry to report that it’s still not working. I tried in Chrome and in Firefox.
    Can you try adding this code?:
    add_filter( 'pre_http_request', function( $pre, $args, $url ) {
        if ( 'https://generateblocks.com' === $url || 'https://generateblocks.com/' === $url ) {
            return wp_remote_post(
                'https://api.generateblocks.com',
                    array(
                        'timeout' => $args['timeout'],
                        'sslverify' => $args['sslverify'],
                        'body' => $args['body'],
        return $pre;
    }, 10, 3 );
  • Hi Tom – code snippet added to the Child Theme functions.php and it worked! Thanks very much for the solution!
    I will now marked this topic as resolved, and will remove the tempadmin login access.
    Thanks to all on the GP & GB support team for this help and the continued great support!
    Cheers,
    Meg
Viewing 16 posts - 1 through 16 (of 17 total)
