Lightbox and theme.json
    I noticed that Guternberg now has the option to open images and gallery images in a lightbox. However, to get it to open in Lightbox by default, I need to create a theme.json file with the following code:
    			"core/image": {
    				"lightbox": {
    					"enabled": true
    However, once I upload this json file to my theme directory, the formatting in my editor seems to be messed up slightly, as instead of the content blocks being center-aligned, they now become left-aligned.
    I understand that GP does not normally support theme.json. Is there any other way to support the lightbox feature in GeneratePress?
    You can try this snippet:
    add_filter('wp_theme_json_data_default', function ($theme_json_data) {
        $new_data = [
            'version' => 2,
            'settings' => [
                'blocks' => [
                    'core/image' => [
                        'lightbox' => [
                            'enabled' => true
        return $theme_json_data->update_with($new_data);
    This works in my testing, let me know if it works on your end.
  • Hi Alvind
    Is it possible to add a section to this code so that the lightbox looks like a slide gallery?
    Thaks
  • Not sure about that, though. I didn’t see any reference on how to add that in the WordPress documentation.
    I’m trying to add this code snippet in fuction.php so that the lightbox works as a slide, but it doesn’t seem to work.
    I need to know if the theme has jquery atico and if it works with Featherlight.
    `php
    add_filter(‘wp_theme_json_data_default’, function ($theme_json_data) {
    $new_data = [
    ‘version’ => 2,
    ‘settings’ => [
    ‘blocks’ => [
    ‘core/image’ => [
    ‘lightbox’ => [
    ‘enabled’ => true
    function enqueue_lightbox_gallery_scripts() {
    // Enfileirar Featherlight CSS e JS
    wp_enqueue_style(‘featherlight-css’, ‘https://cdnjs.cloudflare.com/ajax/libs/featherlight/1.7.14/featherlight.min.css’, array(), ‘1.7.14’);
    wp_enqueue_style(‘featherlight-gallery-css’, ‘https://cdnjs.cloudflare.com/ajax/libs/featherlight/1.7.14/featherlight.gallery.min.css’, array(), ‘1.7.14’);
    wp_enqueue_script(‘featherlight-js’, ‘https://cdnjs.cloudflare.com/ajax/libs/featherlight/1.7.14/featherlight.min.js’, array(‘jquery’), ‘1.7.14’, true);
    wp_enqueue_script(‘featherlight-gallery-js’, ‘https://cdnjs.cloudflare.com/ajax/libs/featherlight/1.7.14/featherlight.gallery.min.js’, array(‘jquery’, ‘featherlight-js’), ‘1.7.14’, true);
    // Adicionar script para inicializar a galeria com suporte a slider
    wp_add_inline_script(‘featherlight-gallery-js’, ‘
    jQuery(document).ready(function($) {
    $(“.wp-block-gallery, .gallery”).each(function() {
    $(this).find(“a”).attr(“data-featherlight”, “image”);
    }).featherlightGallery({
    previousIcon: “◀”, // Código do ícone para voltar
    nextIcon: “▶” // Código do ícone para avançar
    add_action(‘wp_enqueue_scripts’, ‘enqueue_lightbox_gallery_scripts’);
    WP loads jQuery by default.
