Limit characters on next/prev post titles
  • birdhousedigital
    Hi, I’m using {{post_title source:next-post}} in buttons to show the title of the next or previous post. This works well but I’m wondering how I set a max character limit on this as a few of the post titles are too long and it doesn’t look great?
    Many thanks.
    You can try this snippet:
    add_filter('generateblocks_dynamic_tag_output', function ($output, $options) {
        if (isset($options['trim-title'])) {
            if (!empty($output)) {
                $num_words = !empty($options['trim-title']) && is_numeric($options['trim-title'])
                    ? intval($options['trim-title'])
                    : 3;
                return wp_trim_words($output, $num_words, '...');
        return $output;
    }, 10, 2);
    Then, in your dynamic tag, use it like this:
    {{post_title source:next-post|trim-title}}
    By default, it will trim the title to 3 words.
    If you want to specify a custom word count (e.g., 4 words), use:
    {{post_title source:next-post|trim-title:4}}
  • birdhousedigital
    Works perfectly.
    Thank you.
  • You’re welcome.
