Line Height Footer Paragraph
    I’m trying to set the line height with css of the postal address that cab+n be found on the right in the footer (under Kontakt) so it matches the line height of the navigation menus (the line height between menu items) but I can only achieve to change the line height in all elements in the footer at the same time.
    In This Website
    Try adding this CSS:
    .gb-container.gb-container-c4862f6c p {
      line-height: 1.7;
      padding-bottom: 0.45em;
    perfect thank you so much.
    The padding-bottom was definitely missing in all my tries.
    Cheers!
  • You’re welcome! 🙂
