Link Post format – open in new tab
    I’m trying to achieve something similar to this …
    https://generatepress.com/forums/topic/link-post-format-open-in-new-window/
    … but with a custom post type (called ‘job’), and opening in a new tab instead of a new window.
    Thank you,
    Mark
    A quick way would be using a button block, set the dynamic text tag to {{post_permalink}} then you can toggle the Open link in a new tab option.
    Here’s a screenshot for your reference:
    https://app.screencast.com/ppGLp82P2K5iV
  • Hey, thanks for your help appreciate the fast reply.
    That’s an option but I was hoping to set the post title to a < h3 >, and the button suggestion above only seems to work if the button element is < a >.
    Is there another option I can try please?
    Thank you,
    Mark
  • Hi Mark,
    You can use this snippet:
    add_filter('generateblocks_dynamic_tag_output', function ($output, $options) {
        if (isset($options['open_in_new_tab'])) {
            $output = str_replace('<a href=', '<a target="_blank" href=', $output);
        return $output;
    }, 10, 2);
    Then use this snippet for the post title dynamic tag: {{post_title link:post|open_in_new_tab}}
  • Thanks for the workaround code. It would be nice to have this as switches, like for other links: new tab, nofollow, and sponsored. After all, these are all links, how are these dynamic links different?
    Anyway, your code is a nice example of how to manipulate the output. Could come in handy for other applications, too.
  • Thanks, I’ll pass this feedback along to the dev team so we can look into improving it. 🙂
