Linked featured image should be equipped with the class smooth-scroll
  • Hi team,
    on this page the upper picture (featured image) was linked and jumps to the title of the page.
    The link should be equipped with smooth-scroll.
    But where should I set this? If I assign the class smooth-scroll to the image, then not the link gets this class, but the image itself.
    And then of course it does not work with smooth-scroll.
    How do you have to do it?
    Thank you!
    Try adding the link and the class to the container that wraps the image, rather than to the image itself.
    thanks that works.
    But unfortunately the link ends up way too far down and the header then covers the headline.
    I have this css in my child theme, but it doesn’t seem to do anything…
    [id] {
      scroll-margin-top: 56px;
  • Can you remove the smooth-scroll class from the image?
    Let me know when it’s done.
  • Hi Ying,
    the image has no smooth-scroll class.
    I did it the way Alvind suggested.
  • Can you remove the smooth-scroll class, no matter where it was added?
  • Ok, yes I did that now.
  • Now the scroll-margin-top CSS works.
    So from now on, do NOT use the smooth-scroll class anymore, as now browsers can smooth scroll with just CSS:
    html, body {
        scroll-behavior: smooth;
  • Thanks for your answer.
    But I only want to use the scroll-behavior: smooth for certain links, not for the entire site.
    The navigation, for example, should also jump to certain IDs, but not with smooth.
    How can I set it so that it only applies on this page (in this Element) for the #title?
  • In this case, you need to use smooth-scroll class as it’s triggered by JS.
    But it conflicts with the scroll-margin-top CSS, so you will need to write custom JS to overcome this issue, or use GP’s sticky navigation.
  • But it conflicts with the scroll-margin-top CSS, so you will need to write custom JS to overcome this issue
    I see.
    Then it remains with “hard scroll”.
    Thanks 🌷
  • You are welcome   🙂
