LinkedIn Post Inspector does not detect featured image on blog posts
  • Hello GeneratePress team,
    I’m experiencing an issue when sharing blog posts built with GeneratePress on LinkedIn.
    When using the LinkedIn Post Inspector, LinkedIn correctly detects:
    the page URL
    the title (og:title)
    the description (og:description)
    However, it still reports “Image: No image found”, even though a valid Open Graph image is clearly present in the page source.
    The image is:
    publicly accessible
    HTTPS
    larger than LinkedIn’s minimum requirements (1600×400)
    https://www.linkedin.com/help/linkedin/answer/a521928/making-your-website-shareable-on-linkedin?lang=en-us&intendedLocale=en
    correctly rendered on other platforms (WhatsApp, Facebook)
    Despite this, LinkedIn sometimes falls back to the author avatar instead of the featured image.
    I understand that Open Graph tags are primarily handled by SEO plugins (Yoast in this case), but I’m wondering whether GeneratePress markup or image handling could affect how LinkedIn identifies the primary image of the page (e.g. featured image vs author image).
    My questions:
    Does GeneratePress do anything specific that could influence which image LinkedIn treats as the primary image?
    Is there a recommended way (hook, filter, or setting) to ensure that the featured image is always the dominant image for social sharing, especially for LinkedIn?
    Are there known issues or best practices with GeneratePress + LinkedIn sharing?
    Thank you for your help. I’m happy to provide additional test URLs or details if needed.
  • Hi there.
    This isn’t a GeneratePress issue – the theme doesn’t control Open Graph meta tags, that’s handled entirely by your SEO plugin (Yoast).
    Since the OG tags are correctly present in your page source and other platforms like Facebook and WhatsApp detect the image properly, this appears to be LinkedIn’s Post Inspector having trouble with your specific page.
    LinkedIn’s scraper can be inconsistent – sometimes it reports ‘No image found’ even when valid og:image tags exist. Sometimes, it can read an image if it is presented before the featured image in the source code. In your case, the author avatar is placed before the featured image. A few things to check with your SEO plugin:
    Verify featured images are enabled for posts in Yoast’s Social settings. What happens when you actually upload a featured image for this post in Yoast’s Social tab?
    Try forcing a re-scrape in LinkedIn Post Inspector (sometimes takes multiple attempts)
    Since this is specific to LinkedIn’s platform and your SEO plugin configuration, I’d recommend reaching out to Yoast support for LinkedIn-specific troubleshooting.
