Linking to email address via acf + embed codes
  • birdhousedigital
    I have a custom field called email_address which contains an email address. I want a button to link to this. When I add {{post_meta key:email_address}} I get the domain portion of the address only. How do I link to the actual email address?
    My second question is about an elfsight embed code. I have this in an acf field, and want to show it via a template. I have this added to my template as {{post_meta key:linkedin_embed_code}} however it’s not coming through?
    Many thanks,
    Abby
    I can’t view the page because it seems to require authentication.
    Regarding the email address link, do you mean that clicking it should open the mail client?
  • birdhousedigital
    Yes! Sorry, I’ve removed the URL protection so you can now access the staging site.
  • For the email link issue, try adding this snippet:
    function modify_email_links($block_content, $block)
        // Only modify blocks that contain the "Button1" class or other identifier
        if (strpos($block_content, 'Button1') !== false) {
            // Use regex to find email addresses in href attributes
            $pattern = '/<a[^>]*href="http:\/\/([^"@]+@[^"]+)"[^>]*>/i';
            $replacement = '<a class="gb-text Button1" href="mailto:$1">';
            // Replace the http:// link with mailto:
            $block_content = preg_replace($pattern, $replacement, $block_content);
        return $block_content;
    add_filter('render_block', 'modify_email_links', 10, 2);
    For the secind issue – I see that you’re using the HTML block for the embed code. Unfortunately, Dynamic Tags are not supported in the HTML block—or in any non-GB block, for that matter.
  • birdhousedigital
    Thanks, the email snippet works perfectly.
    The html field was just a left over from some testing. Above it is the text field with the dynamic tag.See photo at https://snipboard.io/qx0KRk.jpg
    I have another question. I have a dynamic image field where I which is pulling in images. Some posts have 4 and some have 3. I have this set as a 4 column grid, however where there are only 3 images being pulled in is it possible to have the grid centred on the page, rather than 3 images and then one empty column? Ideally I’d use a carousel but I’m tying to stick with GB for simplicity at this point.
  • Thanks, the email snippet works perfectly.
    Actually, you don’t need this snippet if you are using v2. I think Alvind might’ve overlooked the problem.
    You can add mailto: before the link destination, so if your dynamic link for link is {{post_meta key:email_address}}, you just need to change it to mailto:{{post_meta key:email_address}}.
    Here’s a screenshot for your reference:https://app.screencast.com/Bj2NKFazearUj
    I don’t think it’s possible, but I can take a look at it, where can I see it?
  • birdhousedigital
    Oh that’s even better. I thought I’d tried that configuration for the email but obviously I’d done it wrong somehow!
    This is in my Partner City Content template, and is the container called ‘Unique Venues’.
  • 1. select the Looper block of the section, go to the style tab, click More button to open up the selector panel, click +New to create a new selector, then enter :not(:has(.gb-loop-item:nth-of-type(4))), and toggle the Compound selector option.
    2. Now you’ve create a selector called .gb-looper-6ecee2dc:not(:has(.gb-loop-item:nth-of-type(4))), set width to 75%, margin-left and margin-right to auto, and set grid-template-columns to repeat(3,minmax(0,1fr)).
    I’ve made the change in your element, please take a look 🙂
  • birdhousedigital
    That’s fantastic – thank you!
    Just the elfsight embed code now. It is in my template as {{post_meta key:linkedin_embed_code}} however it’s not coming through?
  • Sorry I can not find it, there’s a lot of content in that element, Can you let me know which block it is?
  • birdhousedigital
    Yes there is!
    It’s in the container called ‘linkedIn embed’.
    https://snipboard.io/scBpT6.jpg
  • The content in the text area field has HTML tags like <script>; the dynamic tag might not support html tags.
    Can you try adding static text to the text area to see if the dynamic tag can pull the data?
  • birdhousedigital
    Ah yes, it pulls through static text and also a direct LinkedIn embed. Just not the elfsight code. I’ll look for another way to pull the LinkedIn feed into the site.
  • Hopefully ACF shortcode will work for that one 🙂
