Little help with sticky positioning
  • I want to make the accordion “Daftar isi” here to be sticky.
    Setting the accordion block > position > sticky with top 50px still not working in the published page.
    Even though at the gutenberg editor showing sticky behaviour.
    Any ideas?
    A sticky element requires a parent container with sufficient height for it to stick within. In this case, the parent container (.gb-element-fdd5a06c) is only as tall as the accordion itself, so position: sticky has no effect.
    Alternatively, you can place the accordion in a separate Sidebar element. Once that’s done, we can apply CSS to make it sticky.
  • but if you see here, the parent container (.gb-element-fdd5a06c) is taller than the sticky accordion. Still the sticky has no effect.
  • Visually it looks that way, however you can clearly see the container height in the browser inspector. See this screenshot: https://cln.sh/gJTXmdmglx0lHMT2JtHk
  • Should I make another container inside the column to make the sticky works?
  • Try adding this CSS:
    body {
        overflow-x: auto !important;
  • Added the CSS, still no effect🥲
  • Could you try moving the Grid block out of its wrapper Container (gb-element-7e6aac2a) so that the Grid block becomes the parent container?
  • Still unlucky Alvind.
    But then I asked Gemini what might be the culprit, it’s overflow: hidden; auto or scroll. Found it in the Customizer > Additional CSS
    html {
        overflow-x: hidden;
    Since I need that for a quick fix on certain page, I’ll make a custom hook instead.
    Thanks Alvind & Ying
  • No problem, let us know if there’s anything else you need help with.
