George
I have created a plugin that loads the post content of a custom post type
portfolioinside a modal. I have created a content template for that custom post type that includespost_contentand also a shortcode that displays a slider with images from an ACF repeater field. The shortcode is set up infunctions.phpand included inside the content template but as it’s not part ofthe_content, it’s not being displayed inside the modal.Is there a way to load content that includes data from the content template instead of just
the_content? Not sure if I am clear enough.Here is the plugin PHP:
function custom_post_modal_scripts() { // Check if the current page is the archive page of the "portfolio" custom post type if (is_post_type_archive('portfolio')) { // Enqueue styles and scripts only for the "portfolio" custom post type archive wp_enqueue_style( 'custom-post-modal-style', plugins_url( 'custom-modal-style.css', __FILE__ ) ); wp_enqueue_script( 'custom-post-modal-script', plugins_url( 'custom-modal-script.js', __FILE__ ), array(), null, true ); // Localize the ajaxurl variable wp_localize_script( 'custom-post-modal-script', 'custom_post_modal_ajax', array( 'ajaxurl' => admin_url( 'admin-ajax.php' ) ) ); } } add_action( 'wp_enqueue_scripts', 'custom_post_modal_scripts' ); function custom_post_modal_markup() { echo '<div id="custom-post-modal" class="custom-post-modal"> <div class="custom-post-modal-content"> <span class="custom-post-modal-close">×</span> <div id="custom-post-modal-content"></div> </div> </div>'; } add_action('wp_footer', 'custom_post_modal_markup'); // Place the loading spinner outside the modal markup function custom_post_modal_loading_spinner() { echo '<div id="loading-indicator" class="loading-spinner-wrapper"> <div class="loading-spinner"></div></div>'; } add_action('wp_footer', 'custom_post_modal_loading_spinner'); function fetch_custom_post_content() { $post_id = isset( $_POST['post_id'] ) ? intval( $_POST['post_id'] ) : 0; $post = get_post( $post_id ); if ( $post ) { $post_title = get_the_title( $post_id ); $post_content = apply_filters( 'the_content', $post->post_content ); // Output both the title and content echo '<h2>' . $post_title . '</h2>'; echo $post_content; } else { echo 'Post not found for ID: ' . $post_id; } die(); } add_action( 'wp_ajax_fetch_custom_post_content', 'fetch_custom_post_content' ); add_action( 'wp_ajax_nopriv_fetch_custom_post_content', 'fetch_custom_post_content' ); -
whats inside the Content Template that contains data ?
George
Hey David.
A flex container with two inner containers, one containing the slider shortcode and the other a GPP dynamic block set to display the content.
So this:
that includes data from the content templateWhat do you mean by that ? Whats the data ?
Perhaps it might be easier to explain whats not working 🙂
George
Hey David, I’ve attached a video if you want to have a look!
Very nice 🙂
Not sure the best approach on this;
instead of calling the single post inside the modal you would need to call the template which in turn returns the content. -
George
I have a suspicion that the
generate_do_template_partfilter might have something to do with it. Is there some kind of documentation I could have a look at? -
The function can be seen here:
Apart from the before and after action hooks it adds a filter for the template part to be loaded.
So when the
generate_do_template_partfunction is called eg.It calls the template part as specified eg.
content-single -
George
content-singleSo what would it be for a single CPT called
portfolio-new? -
Depends, for example if you had a content template for the single CPT it would need to be named:
content-portfolio-new`But…. what happens when you use a GP Block Element Content Template it disables the content template and Hooks in your element into the after hook.
George
You mean the
generate_after_do_template_parthook?Is is possible to insert that hook somewhere else with PHP?
Thats correct, the GP Element is hooked into:
generate_after_do_template_partI am not sure what you mean 🙂
How is the Modal outputting the Post ? -
George
The answer in on my first post.
George
Towards the end of the code block.
Have you tried including your Shortcode in your fetch custom post function eg.. after the
echo $post_content;? -
George
Yeah, I tried this:
function fetch_custom_post_content() { $post_id = isset( $_POST['post_id'] ) ? intval( $_POST['post_id'] ) : 0; $post = get_post( $post_id ); if ( $post ) { $post_title = get_the_title( $post_id ); $post_content = apply_filters( 'the_content', $post->post_content ); // Add your shortcode here $shortcode = '[portfolio_slider]'; // Concatenate the shortcode to the post content $post_content .= do_shortcode( $shortcode ); // Output both the title and content echo '<h2>' . $post_title . '</h2>'; echo $post_content; } else { echo 'Post not found for ID: ' . $post_id; } die(); } add_action( 'wp_ajax_fetch_custom_post_content', 'fetch_custom_post_content' ); add_action( 'wp_ajax_nopriv_fetch_custom_post_content', 'fetch_custom_post_content' );It’s not loading it but I believe the code is correct, it’s just that this particular shortcode is not rendering (I have tried a few simpler ones, eg, to display the current date and it worked). I will probably need to adjust something in order to be able to display the slider shortcode, which is this, by the way:
//Portfolio slider shortcode function portfolio_slider_shortcode() { // Log a message to indicate that the shortcode function is being executed error_log('Portfolio slider shortcode called'); $images = get_field('gallery'); ob_start(); if ($images): ?> <section class="splide" aria-label="Splide Basic HTML Example"> <div class="splide__track"> <ul class="splide__list"> <?php foreach ($images as $image): ?> <li class="splide__slide"> <img src="<?php echo esc_url($image['url']); ?>" alt="<?php echo esc_attr($image['alt']); ?>" /> </li> <?php endforeach; ?> </ul> </div> <?php endif; return ob_get_clean(); } add_shortcode('portfolio_slider', 'portfolio_slider_shortcode');I want to worry about one thing at a time, though.
Is it possible to insert the single portfolio content into that modal? I have created a certain layout as a content template and I want that displayed inside the modal. Is that clear?
