Load editor-style.css
  • Hi all,
    I am using a child theme and would like to use my own CSS in the editor.
    I have this code in the functions.php file in the generatepress_child directory:
    add_action( ‘after_setup_theme’, ‘generate_child_setup’ );
    function generate_child_setup()
    add_editor_style( ‘editor-style.css’ );
    The editor-style.css file is located in the same directory.
    Unfortunately, the file is not loaded in the editor.
    Why is that?
    Give this code a try:
    add_filter( 'generate_editor_styles', function( $editor_styles ) {
        $editor_styles[] = 'editor-style.css';
        return $editor_styles;
  • Hi Ying,
    unfortunately, the file still won’t load.
    It looks like there is no stylesheet file named editor-styles.css in your child theme. I can only see the default style.css file: https://cln.sh/TXlcrp3Q4brZMDDZGHpJ
    If you were referring to the style.css file, then this snippet should work:
        $editor_styles[] = 'style.css';
  • Hi Alvind,
    the file editor-style.css is there. I added a screenshot.
  • Try adding this snippet as well:
    function ac_enqueue_custom_styles() {
        $stylesheet_path = get_stylesheet_directory() . '/editor-style.css';
        wp_enqueue_style(
            'editor-style-css',
            get_stylesheet_directory_uri() . '/editor-style.css',
            array(),
            filemtime($stylesheet_path)
    add_action('wp_enqueue_scripts', 'ac_enqueue_custom_styles');
    in addition to Ying’s snippet above.
