BrightIdiots
We recently translated our site, with the structure: example.com/en/slug/ and example.com/es/slug/ etc.
For those pages/post I want to exclude (and include) some scripts. Without adding all these pages separate, is there a way to include/exclude scripts via Elements on URLs that contain /en/ or /es/ etc…?
There’s a filter called
generate_element_display
you can use for this. Reference: https://docs.generatepress.com/article/generate_element_display/Usually, a conditional code like
get_locale() == 'en'
is used in conjunction with the filter for these instances.Example snippet:
add_filter( 'generate_element_display', function( $display, $element_id ) { if (1234 === $element_id && get_locale() == 'en') { $display = true; } else if (5678 === $element_id && get_locale() == 'es') { $display = true; } return $display; }, 10, 2 );
You’ll need to replace 1234 and 5678 with the Element ID of the respective Element.
Getting the Element ID: https://share.getcloudapp.com/YEuDdrnQ
You’ll need to check if that conditional statement will work for the plugin you used for the language change.
BrightIdiots
Thanks for your reply! Just tried adding this code, but doesn’t seem to work.
This is what I added
add_filter( 'generate_element_display', function( $display, $element_id ) { if (8790 === $element_id && get_locale() == 'en') { $display = false; } else if (8790 === $element_id && get_locale() == 'es') { $display = false; } return $display; }, 10, 2 );
Is there any other option?
What plugin are you using for the language? Let’s see what needs to be altered for the conditional statement to work.
BrightIdiots
We use Gtranslate for this
Are you using the paid version of that plugin? If so, they have a way to check the current plugin used through a code like this:
$current_lang = isset($_SERVER['HTTP_X_GT_LANG']) ? $_SERVER['HTTP_X_GT_LANG'] : '';
BrightIdiots
Yes, we’re using the paid version. What code do I have to use in combination with Generatepress for this to work?
Can you first create a Hook Element with this code:
<?php $current_lang = isset($_SERVER['HTTP_X_GT_LANG']) ? $_SERVER['HTTP_X_GT_LANG'] : ''; var_dump($current_lang ); ?>
Hook it to
before_header
.Make sure to enable PHP in the Hook settings, and set the display rule to the entire site.
It’s best to do this on a staging site.
Let us know what appears on top of the page on an en and es page.
This way, we can construct a code that would have an appropriate conditional statement.
BrightIdiots
I just made a staging, but Gtranslate doesn’t allow the translation there. So I just added the snippet briefly to the live site, and it mentions on /en/
string (2) "and"
is that all that gets displayed on the site with Fernandos code ?
BrightIdiots
It depends on the selected language:
string(0) ""
– main languagestring (2) "and"
– Englishchaîne(2) "fr"
– French -
Ok, so if you make a note of the string values for each language then you can include them in the function like so:
add_filter( 'generate_element_display', function( $display, $element_id ) { $current_lang = isset($_SERVER['HTTP_X_GT_LANG']) ? $_SERVER['HTTP_X_GT_LANG'] : ''; if (8790 === $element_id && $current_lang == 'and') { // display false if lang property contains and $display = false; } return $display; }, 10, 2 );
BrightIdiots
This works perfectly!
How would I add multiple languages/ID’s to this code? Or do I copy the code and adjust the language/ID’s.
Additional info: the ‘currentlang’ is translated: the translation of the Dutch word ‘EN’ is ‘AND’. So the language has to be ‘en’, or ‘fr’ etc.
Yes, just expand the code. Example code:
add_filter( 'generate_element_display', function( $display, $element_id ) { $current_lang = isset($_SERVER['HTTP_X_GT_LANG']) ? $_SERVER['HTTP_X_GT_LANG'] : ''; if (8790 === $element_id && $current_lang == 'en') { // display false if lang property contains en $display = false; } else if (8791 === $element_id && $current_lang == 'fr') { // display false if lang property contains fr $display = false; } return $display; }, 10, 2 );
BrightIdiots
Thanks Fernando and David, this works perfectly!
You’re welcome!
