Local pattern library items not inserting
  • I recently launched a website built on GP with GB Pro and everything was working fine on the dev site. But as soon as it went live on production, a few GB items stopped working.
    The main issue right now is that I can’t add anything from the Local Pattern Library. The library opens and displays the patterns, but when I click “Insert” it just spins and nothing happens, even after waiting several minutes.
    The “Free” and “Pro” patterns insert just fine, but nothing from the “Local” library will insert.
    I have cleared my browser cache and deactivated all other plugins, but it did not make a difference.
    Thanks for the details! This looks like a leftover reference to your staging domain — a common issue after site migrations.
    A couple of things to check:
    1. Check wp-config.php
    Your Settings → General fields are greyed out because the URLs are hardcoded in wp-config.php. Open that file and look for lines like these:
    define( 'WP_HOME', 'https://[mysite].mystagingwebsite.com' );
    define( 'WP_SITEURL', 'https://[mysite].mystagingwebsite.com' );
    If they’re still pointing to your staging domain, update them to your production URL.
    2. Run a database search and replace
    Even if wp-config.php looks correct, there may be staging URLs stored in the database. Use a plugin like Better Search Replace to search for your old staging domain and replace it with your production URL — make sure to do a dry run first before committing any changes.
    3. Resave your permalinks
    After making any changes, go to Settings → Permalinks and click Save Changes to flush the rewrite rules.
    4. Clear all caches
    Clear any caching plugin cache as well as your CDN/Cloudflare cache if applicable.
    Once the staging domain references are cleaned up, the Local Pattern Library inserts should start working again. Let us know how it goes!
  • Thanks for the response! I checked the wp-config file (no URLs hardcoded in there), I did a database search and replace, and resaved the permalinks. We don’t have any caching plugins installed.
    Unfortunately the issue is still happening.
    You also seem to have an issue with the fonts. They seem to be referencing the staging site. Even though I don’t think it’s related, it’s worth fixing. Could you try deleting and re-adding the local fonts in the Font Library?
    Let me know when done. I have also noticed that some local patterns are actually being imported, most of it fail, though. Try the font solution first and we can take it from there.
    Ok, I have deleted and re-added the fonts. Didn’t seem to make a difference for the patterns though!
    This does appear to be a bug. I’m able to reproduce the exact same issue on my end, so I’ll raise an issue for the team to get it fixed.
    Thanks for reporting this.
  • Ok, thank you!
