Loop Item
  • Hello, I am creating a Loop Item with blog posts. I have a few questions about it.
    1.
    I have set Post Excerpt as follows: {{post_excerpt length:25}}
    The problem is that the length of the text is not consistent. Sometimes the text has 5 lines and sometimes 3. Is there a way to set the post_excerpt to a specific length? For example, so that it always displays in 4 lines?
    2.
    I can’t find the layout settings for mobile phones (horizontal position). Where can I set this?
    You can check out the test page.
    https://imgur.com/a/i1ujjfX
    1.1 Select the excerpt (gb-text-9e5fe613), add a CSS class to it, eg. my-excerpt.
    Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    1.2 Add this CSS:
    .my-excerpt {
        display: -webkit-box;
        -webkit-line-clamp: 3;
        -webkit-box-orient: vertical;
        overflow: hidden;
        text-overflow: ellipsis;
    2. Select the container gb-element-73d941e6, switch to mobile, and adjust its paddings in the spacing panel.
  • 1. Can I add the CSS code using generateblocks? I still need some advice on this. Or where should I insert the CSS first so that I can then put it into the element using generateblocks – advanced and Another CSS class?
    2. I have the looper set to one column on my phone, which is fine. However, when I rotate the phone (landscape – horizontal), I want two columns to be displayed.
    Thank you very much.
  • Here’s how to add a CSS class to the block:
    And you can add the CSS code to the customizer > additional CSS.
    For the layout, can you try this CSS?
    @media (max-width: 1023px) and (min-width: 400px) {
    .gb-looper-a556d3f4 {
        grid-template-columns: 1fr 1fr;
  • Thank you very much, it works! I have one last question—I can’t insert the URL address for the post into the image, even though the dynamic tag to insert is: {{featured_image key:url}}
    Do you know what the problem is? Alternatively, is there a simple way to make the entire container clickable, not just the title and image?
    Test page: https://vitasimo.cz/v/
  • For the image, you need to assign {{post_permalink}} dynamic tag to its link field:
    https://app.screencast.com/u4Hna3QcmTTWQ
    To create a clickable container, it needs GB Pro or custom CSS if you don’t have GB Pro.
    Here’s the doc to create clickable container for GB Pro users:
    https://learn.generatepress.com/blocks/block-guide/add-container-links/
    If you don’t have GB Pro, try follow steps below:
    1. Add a CSS class to the loop item block, eg. container-link.
    2. Select the loop item block, set its position to relative.
    2. Add this CSS:
    .container-link a:first-of-type:before {
        content: '';
        position: absolute;
        inset: 0;
