Lost ability to choose sidebar layout or remove headers and footers from page
  • Hi, I have a couple questions.
    First, I did something, so now I can’t choose the type of sidebar layout or remove featured image/header/footer…. in the right sidebar.
    Second, I want to use the blank slate plugin to make my homepage just an html page I created with another program, but I don’t have the ability to choose a template, which you have to do to use the blank slate plugin.
    Thanks,
    Ryan
    From your description, it’s not clear what you are trying to do. Can you sent us a URL?
    Regarding your second request: Not sure what you are referring as the blank slate plugin.
  • Don’t worry about the second request. I think I can get that figure out. When editing a blog post or page, on the right side there are options to disable elements and choose sidebar configuration. Mine just disappeared. The disable elements is still activated with generate press . right sidebar doesn't have the options to disable elements and choose sidebar config
  • That is indeed very strange! Could you please provide site credentials so we could have a look for you? Please use the private section of your reply to post them. You can also install the Temporary Login Without Password plugin and send us a login link without using a password. Again, please, use the private area of your reply to send those details.
  • I think I marked this as resolved, but it isn’t. Thanks. The website is drbellhealth.com
  • Ok, no problem, see my previous post.
  • Sent it.
  • Hi, could you also send the URL please? Thanks!
  • drbellhealth.com
    All my pages and posts in the back end do not have the sidebar option.
    I’ve just logged in to the site, visited a page and I can see the layout options in the backend.
    Page layout options
    Those layout options will not be available if an Editor is logged in, though. Could that be the issue?
  • still not showing up for me. maybe a caching issue? Ok, showing up for posts, but not pages.
  • ok. I logged in with the credentials i gave you and it works fine???
  • Could it be that you are logging in as an Editor instead? I don’t think a caching plugin could be so aggressive as to cache those requests. Do you use WP Rocket? Would be worth clearing the cache just in case.
  • I use wp rocket and I am an admin and have cleared cache multiple times. Maybe just create a new user to use and go from there. Thank you for your help.
  • Hmmm strange. Anyway, no problem, let us know if you need more help!
Viewing 15 posts - 1 through 15 (of 15 total)
