mailchimp sign up form
  • Hi I am just wondering if there are anyways to set up mailchimp forms within GP/GB pro?
    As in, to style them within call to actions and blocks to insert into pages
    thank you
    it is possible, but probably easier with some CSS as those forms HTML and CSS are not always that “clean”
    If you can share a link to where I can see the mail chimp form on your site – we can take a look and advise.
  • Ok I have popped it at the bottom of this blog post for now.
    https://nfebranding.co/flat-lay-photography/
    The fields can either be added via shortcode block, or can paste the full code
    Essentially what I would like to know is if I can force the fields to be horizontal. You can see I have put it in a container, auto margin either side, given it a background colour and a heading within the container. So I think I can style in a way that could work, if it were possible to code it to tell the fields to only stack on mobile.
    What do you think?
    thanks 🙂
  • So the HTML is lightweight but has some oddities, such as the email field is inside its label. Which adds a little more hoop jumping.
    Try this CSS:
    /* desktop align fields horizontally and reset spacing */
    .mc4wp-form-fields {
        display: flex;
        align-items: flex-end;
        justify-content: center;
        max-width: max-content;
        margin-inline: auto;
        gap: 8px;
        padding: 10px 20px;
    /* remove unnecessary bottom margins */
    .mc4wp-form-fields p {
        margin-bottom: 0;
    /* set the form label font size and transform */
    .mc4wp-form-fields label {
        font-size: 14px;
        text-transform: uppercase;
        font-size: 12px;
    /* position the form labels above input */
    .mc4wp-form-fields :is(p,label,input) {
        display: flex;
        flex-direction: column;
        align-items: flex-start;
    /* set the input font size and height */
    .mc4wp-form-fields p input {
        font-size: 14px;
        line-height: 1;
        border-radius: 3px;
    /* style the form input button */
    .mc4wp-form-fields p input[type="submit"] {
        font-weight: 700;
        padding-block: 11px;
        border-radius: 20px;
    /* stack the fields on mobile */
    @media(max-width: 768px) {
        .mc4wp-form-fields, .mc4wp-form-fields :is(p, label ) {
        .mc4wp-form-fields p:last-of-type, input[type="submit"] {
            width: 100%;
            align-items: center;
            margin-top: 2px;
    It gives the row layout for desktop and stacked for mobile.
    I also added a smaller radius corner to the input fields, and styled the submit to match your site buttons
    Let me know
  • Oh wow thank you so much for all the effort!
    Does this go in additional css in the customiser?
    I did that and cleared cache and it does not seem to have done anything, so I might have done something wrong. I will check in tomorrow morning as it is late here in AU
    thanks Renee
  • Yes in the Customizer > Additiobal CSS>
    See here:
    /* End remove alt text on hover */
    body.single #comments {
        max-width: 900px;
        margin: auto;
    .comment-content {
       padding-top: unset;
       padding-bottom: unset;
    That is the CSS before it. And its. missing a closing }
    That CSS needs to be replaced with:
        max-width: 900px;
        margin: auto;
    .comment-content {
       padding-top: unset;
    That will fix the error and then the CSS below it will work.
  • Perfect – that is great and works now.
    Now I can style it, thank you so much for the help 🙂
  • You’re welcome
