Main nav menu sticky when I don’t want it to be
  • Hi team,
    Please see the site provided in the private section. You will see the nav menu (but not the header) is behaving as a “sticky” element, when I actually don’t want this and have set it up that way.You have to look carefully to see it as the sticky text is white.
    I can’t see how to change that.
    Can you help please.
    Rick
    If you want to disable the sticky navigation, go to customizer > layout > sticky navigation, and turn it off from there.
    Let me know if this helps!
  • Thanks- that did the trick!
  • You are welcome   🙂
