Make a reusable image slider
  • Hi. I’d like to make a reusable image slider. Let’s say I use this one https://www.w3schools.com/howto/howto_js_slideshow.asp
    It has three parts: HTML, CSS, JS
    CSS: goes into global styles
    HTML: add it through patterns, then ‘detach’ it when adding to a new page, and edit the URLs with new images.
    JS:
    1. create an Element block with JS (element type: post meta template; location: custom; hook name: wp_footer).
    2. Create a custom field “image-slider” on the page I want to display the slider on.
    3. Add conditional logic to the Element to display it only on pages with the custom field “image-slider”
    Is it a correct approach? I’m missing something since it doesn’t work properly.
  • Abort mission, it actually works. I just added the Element in another block, and it was messing it up.
    Also, changed the Element to:
    ELEMENT TYPE: hook
    HOOK NAME: wp_footer
    But if I can get a comment on my logic, please do so 🙂
  • Glad to hear that 🙂 Your approach is correct!
