scottymo
Hi there the big black area at the top i would like to make it around 80% smaller. I’m refering to the height, not the width.
Its an existing “element” within the generatepress theme.
Screenshot in the private area.
Many thanks!
which template are you using?
or can you link us to the page in question on your site?
scottymo
Hi Ying!
I put the page in the private thing. I am using the “wander” eCommerce theme.
Select the container, then reduce the top padding under Spacing settings; it’s currently set to 200px.
scottymo
Thanks! It worked for desktop. Anything i have to do to make it work on mobile too? Many thanks.
It’s the same setting, but switch to the mobile view and change the padding.
