Make Container Flush With Footer
  • Hello, I’m trying to make containers flush with the footer, such that the background is not visible at all. For reference, the background is colored red in the links provided. I’ve attempted adjusting the sizing/padding of the container, footer, as well as the Container menu within the theme customizer without any luck – how can this be accomplished? Thanks!
    The space that’s showing the red background is because of the top margin set on the Container Block in your Footer.
    Can you remove the 100px top margin in your Container?
  • Yes that resolves the issue! Thank you for the quick reply!
  • You’re welcome, BigTex!
