smarterwebpackages
I want to casually describe this to prevent confusion and get me closer to the pagination at hand.
1. Create a CPT for example: “movies”
2. Create a CPT for example: “genre”
3. Input several entries on the movie CPT
4. Input one entry on the genre CPT for example: “scifi”
5. Create a template for the genre CPT (single-genre.php)
6. In single-genre.php, create a custom query to pull ALL “movies” to be displayed in the “scifi” entry of genreNumber 6 works without an issue except pagination. It’s able to display a list of all “movie” cpt titles up to the maximum designated. It even shows the pagination properly. You can see the gist of single-genre.php code I coded.
But pagination doesn’t work properly in single-genre.php. If this same code was placed on the “front-page.php”, it would work, I just needed to add use the line below:
$paged = ( get_query_var( ‘page’ ) ) ? get_query_var( ‘page’ ) : $paged; // For static front pages
MY QUESTIONS:
1. Do you know how I can fix the pagination in this scenario where I’m pulling a queries of CPT (ex: movies) while putting it on a single-genre.php template of a different CPT (ex: genre)?
2. Is there a custom php solution assuming I were to create a shortcode (or a block) so I can manually code PHP instead of simply using the somewhat limited query blocks?All I really care about is making pagination work. I have intentionally made the example simple enough to at least solve that problem first. Thank you for your help.
Single post templates don’t support pagination by default because WordPress expects them to display only one post. Adding
/page/2/to a single post URL causes WordPress to get confused.Does the Genre need to be a CPT? You could switch it to a custom taxonomy instead, this would give you proper archive pages with built-in pagination.
Right now, you’re trying to show a paginated list of one CPT (movies) inside the single post template of another CPT (genre), and WordPress doesn’t natively handle pagination in that context.
smarterwebpackages
I completely understand what you’re saying and I’ll put the pagination issue to rest on a single post (I can make just use custom taxonomy instead). This issue is resolved.
Glad to hear that! 🙂
