Making specific container sticky
  • Hi, I want to make the container within which the alphabet section is located (webpage provided in private) sticky at the top of the page on scrolling down.
    I have tried the following,
    tried but didn’t work
    I would be grateful for any advice.
    It’s not possible based on your current HTML structure.
    You need to change your structure to this, drag the wp-block-group into the parent container of the page, so it becomes a sibling to the alphabet container.
    https://www.screencast.com/t/MAdLSsFdNxOD
    Once it’s done we can take another look.
  • Oh I see, ok done that.
  • To clarify, do you want the entire Dictionary section sticky or just the alphabet buttons?
  • Just the alphabet to be sticky.
  • Try adding this through Appearance > Customize > Additional CSS:
    .gb-container.gb-container-62a240a0 {
        position: sticky;
        top:60px;
    .gb-container.gb-container-b429ea89 {
        position:relative;
    .gb-container.gb-container-a3d597d7 {
        overflow-x:unset;
        overflow-y:unset;
    Add a Background color to the Container Block holding the Alphabet so it appears better.
  • The sticky effect works well.
    However I notice that on mobile, on my landing page one of the buttons (‘BOOKS’) has now become sticky.
  • Can you reshare the exact page in question?
  • Ofc, I have provided it again below
  • Would you want it sticky just on Desktop? I’m not seeing a “Books” button on mobile as well.
  • So, the books button is on the homepage – this has now become sticky.
    Re the alphabet on the /lexicon webpage, I want to habe it sticky on all devices.
  • I see.
    Give the Container Block a make-sticky class. Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Then replace the CSS we had with this:
    .gb-container.make-sticky {
        position: sticky;
        top:60px;
        position:relative;
        overflow-x:unset;
        overflow-y:unset;
  • EDIT: sorted! Now ti appears to work fine. Thank you:)
  • You’re welcome!
