How can I add a mandatory checkbox with text to the newsletter form that the user must tick?
Are you referring to the Form block of Generateblocks Pro plugin?
yes
You can select the form block, click the add form field button, then set the new field’s type to checkbox, toggle the Required option:
https://app.screencast.com/VNRn2YtDJsFrFFor more info:https://learn.generatepress.com/blocks/block-guide/getting-started-generateblocks/generateblocks-pro/forms/#the-form-fields
Okay, but now it looks like this:
https://prnt.sc/SvLNkmMS6bG0But it should look like this:
https://prnt.sc/rHMd0YgPZRqEHow can I get this?
Can you link me to the page where I can see it?
Here is a link to the draft Website.
The checkbox should be aligned directly with the text
Please also take a look at the other problem with this: Insert a email-adress, check the box and click “Abonnieren”. Then the button suddenly becomes very wide, so that you can barely see the email field.
I am not able to view a preview without logging into your site. Can you publish it?
Have you clicked on the link? If not, then do so.
As I said, I can not view a preview link. You need to publish this post so I can see it!
As I said, have you clicked on the link? If not, then do so.
Select the Checkbox Field block.
Under Layout, set Display to Flex.
Then, under Grid Layout, set Grid Column to 1 / -1.
I have done this, but this does not change anything. But what do you mean with: Grid Column to 1 / -1.
Should I put “1 / -1” in that field? -
Yes, exactly like this: https://cln.sh/WsYtk1ftP7vwlnHZBhKh
Okay, but this does not change anything.
Ah, okay. That’s because the Email Field block is currently set to Display – Grid. Can you change its Display setting to Flex ?
