Masking a page/post’s title
  • philipperoussel
    It used to be possible to mask a page/post’s title. I do not see this option anymore.
    Thanks for your help,
    Philippe
    I’m not quite sure what you mean by ‘masking the title.’ Could you please clarify if you intend to hide it?
  • philipperoussel
    Yes, hiding it. Sorry.
    edit the page or post and in the settings sidebar there is the Disable Elements meta box:
    https://docs.generatepress.com/article/disable-elements-overview/
    Check the content title to remove it from the front end.
    If you want to do this conditionally eg. for all Pages the you can use a Layout Element:
    https://docs.generatepress.com/article/layout-element-overview/
  • philipperoussel
    Hi David,
    The issue was that I could not see the Layout element at all. It was hidden at the very bottom of the page. How to bring it back in the right hand side column with the other ones?
  • Not easily… try clicking and holding the top bar of the Layout panel, and then drag it to the very bottom of the sidebar, a marquee area should appear for you to drop it into. But it can be a little tricky
  • philipperoussel
    It worked, but it is not possible to bring the Layout features more than 3 notches up in the right column. One way or another, I know where to find it, and this is what matters.
    Thank you.
  • Yeah, there are some limitations that WP sets on that sidebar.
    Glad to hear you got it back in place!
