Masonry Query Loop
    I’ve been trying to apply a masonry effect to a query loop block in order to display art at the correct aspect ratio without massive gaps vertically. I’ve tried following this thread but am not getting a good result:
    https://generate.support/topic/create-masonry-grid-with-query-loop/
    I have tried adding bottom margin to the loop item but this creates the same problem as not having masonry. E.G. Margin fixes the first item but then all the others have a massive white margin at the bottom.
    Can you point me in the right direction?
    Thanks,
    Nick.
    Please remove any existing JS, set the query looper grid to 1 column, and give it a class of css-masonry.
    Then, use this CSS:
    .css-masonry {
        display: block !important;
        column-count: 3;
        column-width: 250px;
        column-gap: 40px;
    .gb-loop-item {
        break-inside: avoid;
        margin-bottom: 40px
    This sets a 3 column grid, but it will collapse to 2 or 1 when there isn’t space for the 250px column-width.
  • Thats great. Thanks George. Fixed.
  • Glad to know, you are welcome!
