Maximun Title Length
  • I want to set the maximum number of characters for the title. What should I do?
    trimming the title to an exact number of characters can be tricky. Its easier to fix the total number of lines on show, which will keep it more responsive. If thats an option then do this:
    1. Edit that Query Loop block, and select the Headline block with the title.
    1.1 In the block settings Advanced -> Additional CSS Classes add a CSS class; line-clamp
    1.2 save that change
    2. Add this CSS to your site:
    .line-clamp {
        display: -webkit-box;
        -webkit-box-orient: vertical;
        -webkit-line-clamp: 2;
        overflow: hidden;
  • Oh my god!! It was a very difficult problem, but it was solved easily Thank you so much.
  • Glad to be of help!
