How do I make a Mega Menu in Overlay Panel fade in and out in mobile view?
I can only get it to work on desktop.Best regards
Knud -
Hi Knud,
This isn’t currently possible with the built-in Mega Menu animation settings. Fade In and Fade Out animations are intentionally disabled when the Overlay Panel is inside the mobile menu, which is why they only work on desktop.
You can set the Navigation block’s Mobile Menu Transition to Fade, but that fades the entire mobile menu rather than the individual Mega Menu panel.
If the individual panel must fade on mobile, the current workaround is to use a separate Standard Overlay Panel triggered by a mobile-only element.
OK, thanks Alvind…
I’ll try that 🙂 -
Sure, no problem 🙂
