Mega menu with your CSS code: hover issue
    I’ve implemented a mega menu following the instructions from this article:
    https://docs.generatepress.com/article/building-simple-mega-menu/
    I’ve also added some custom styling to improve the visual layout. Overall, it works well — but I’m experiencing one issue I can’t solve:
    Issue:
    When I hover over the “Familierecht” top-level menu, the mega menu appears correctly.
    However, as soon as I move the mouse into the submenu and hover over the second or third column (e.g., “Kinderen & ouderschap”), the submenu of a different top-level item (“Over ons”) opens instead.
    This only seems to happen when hovering down-and-right into the lower columns of the mega menu.
    Please check only the main (Dutch) version of the site; the /en/ version is still incomplete.
    Thanks in advance for looking into this!
    If this is too complicated or requires a lot manual work, is a plugin like https://wordpress.org/plugins/megamenu/ than better to use?
    In the mean time I fixed this with some CSS and javascript.
    @media (min-width: 769px) {
    .main-nav > ul > li.menu-item-has-children .sub-menu {
    opacity: 0;
    visibility: hidden;
    pointer-events: none;
    transition: opacity 0.2s ease;
    .main-nav > ul > li.menu-item-has-children.hovering .sub-menu {
    opacity: 1;
    visibility: visible;
    pointer-events: auto;
    <script>
    document.querySelectorAll(‘.main-nav > ul > li.menu-item-has-children’).forEach(item => {
    let timeout;
    item.addEventListener(‘mouseenter’, () => {
    clearTimeout(timeout);
    item.classList.add(‘hovering’);
    item.addEventListener(‘mouseleave’, () => {
    timeout = setTimeout(() => {
    item.classList.remove(‘hovering’);
    }, 150); // milliseconden delay
    const submenu = item.querySelector(‘.sub-menu’);
    if (submenu) {
    submenu.addEventListener(‘mouseenter’, () => clearTimeout(timeout));
    submenu.addEventListener(‘mouseleave’, () => {
    }, 150);
    </script>
  • Glad to hear that 🙂
