epnageca
I wonder if it would be easy to make a menu effect like on that site : https://leshabitantes.fr/
Maybe any way to copy the css ?
Thanks for your help. -
try this CSS:
@media(min-width: 769px) { .main-nav > ul > li > a { position: relative; --angle-size: 12px; --angle-color: #000000; } .main-nav > ul > li > a:before, .main-nav > ul > li > a:after { content: ''; display: block; width: var(--angle-size); height: var(--angle-size); border: 1px solid transparent; position: absolute; pointer-events: none; opacity: 0; transition: all 0.3s; } .main-nav > ul > li > a:before { border-bottom-color: var(--angle-color); border-left-color: var(--angle-color); bottom: 0; left: 0; transform: translate(100%,-50%); } .main-nav > ul > li > a:after { border-top-color: var(--angle-color); border-right-color: var(--angle-color); top: 0; right: 0; transform: translate(-100%,50%); } .main-nav > ul > li > a:hover:before, .main-nav > ul > li > a:hover:after { opacity: 1; transform: translate(0,0); } }
Notes, in the top CSS rule are 2 CSS variables:
the first sets the size of the angle and the other sets the hexcolor
The overall height and width of their position is based on the Menu Item Height and Width in the Customiser > Layout > Primary navigation.
epnageca
Thanks so much!
You’re welcome
