yderhy
Hello, I use generateblock with hook menu-bar-items, to insert social font awesome with html.
J’utilise également le héros de la page fusionné pour l’en-tête.
Les icônes fontaweome dans generateblock ne changent pas de couleur en tant qu’icône de bascule et de recherche.
Comment puis-je le réparer ?
Thank you -
can i see the issue on your site ? As it may require some CSS
yderhy
thank you
It doesn’t look like you are using GenerateBlocks.
Can you try the buttons block instead?
https://docs.generateblocks.com/article/button-overview/ -
yderhy
I now use the buttons for INSTAGRAM AND CALENDAR. But it doesn’t worK.
I want the button to be in color:white in page hero header, and in color:black when I scroll down. The same CSS than toggle button and search button
Thank you for your help -
Try this CSS:
.main-navigation .menu-bar-items a { color: white; } nav#mobile-header.is_stuck .inside-navigation .menu-bar-items a { color: black; } .main-navigation .menu-bar-item.search-item a { border-left-color: white; } nav#mobile-header.is_stuck .inside-navigation .menu-bar-items .menu-bar-item.search-item a { border-left-color: black; }
yderhy
it is very good except border which is always black
}how can we make it in white
thank you for your help -
The CSS includes the border color, it should work.
Can you clear cache and let me take a look?
yderhy
it works
thank you
