Hi
I installed a starter site and didn’t have any issues. When I attempted to switch starter sites, my menus disconnected. I’m getting “block rendered as empty” message rather then the expected menu items. I haven’t made any modifications, not even colour palette, as I just started the site. When I view the site, there aren’t any menu options visible. How do I correct this?
thanks!
site: https://summerstaging.online/
error image: https://postimg.cc/QVNq6yzq -
Did you remove the existing template when you imported the new template?
And can you go to appearance > menus, check if you have any menus created there?
Summer
Hi, thanks for the reply :). I did remove the existing template. I had all the menus created as well. They were populating then just disappeared. I ended up wiping the site clean and starting again, didn’t encounter the problem again.
Glad to hear that 🙂
